Solved
Gaming Build (Need help)
Hi, I'm new to computer building and I was wondering if I could get some advice to my build.
Case:
COOLER MASTER HAF 922 (89$)
Mobo:
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard (125$)
CPU:
2500k i5 (225$)
GPU:
EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 (356$)
RAM:
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) (53$)
hdd:
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive (150$)
PSU:
Rosewill BRONZE Series RBR1000-M 1000W Continuous@40°C, 80Plus Bronze Certified,Modular (130$)
Optical Drive:
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM (20$?)
OS:
Microsoft Windows 7 Home Premium SP1 64-bit - OEM (100$)
Total is 1270 USD shipped
I'm building the system with expansion in mind so I got a 2 PCI e slot and a hefty power supply. I would also like to cut down the cost to 1100$ but keeping a similar performing GPU. I'm also wondering if I would need some sort of aftermarket cooling for this current set up as I'm not really planning on OCing.
Any help would be appreciated :D
20 answers Last reply Best Answer
More about gaming build need help
  1. Best answer
  2. That's awesome!!! I knew the HDD prices are currently retarded, but I was planning to get one off E-bay Lmao.
  3. No problem.
  4. 1000W is overkill even for SLI. Get 550-650W for single GPU or 850W If you plan to SLI
    PC Power and Cooling Silencer MK III PPCMK3S600 600W ATX12V v2.3 80 PLUS BRONZE Certified Modular Active PFC Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703036
    You can get this value case with USB III in front panel
    NZXT Source 210 Elite White Steel with painted interior ATX Mid Tower Computer Case w/ Black Front Trim
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146077
    And finally get this 750GB HDD which is cheaper
    HITACHI Deskstar 7K1000.D HDS721075DLE630 (0F13179) 750GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822145532
  5. Case:
    NZXT 210 source (50$)
    Mobo:
    CPU:
    2500k i5 (225$)
    GPU:
    RAM:
    hdd:
    Seagate - Barracuda 1TB Internal Serial ATA Hard Drive (55$ ON BEST BUY)
    PSU:
    Optical Drive:
    OS:
    TOTAL SHIPPED: 1137$
    Would I need to worry about aftermarket cooling with this spec? I'm not planning to OC. Also, should I wait for black friday to get the parts for some discounts?
    And as for the 1k Power supply, I looked at some of the 850W modulars and the price difference is like 10$.
    Since when was 55 larger than 110?
  7. So uh...is the build good? o_o What do you think will my FPS avg will be on 1920x1080 21inch monitor for BF3?
    50FPS
    http://www.tomshardware.com/reviews/battlefield-3-graphics-performance,3063-7.html
  9. Build is pretty good but your power supply is not. Do you plan to SLI?
  10. Yes I do! :) What seems to be the problem with it?
    It's a Rosewill PSU, it's not all that reliable. Go with something such as Seasonic, Corsair, or Antec. Also, 1000W is overkill even for SLI x2, it'll be perfect for 3 way SLI tho
  12. So, what wattage am I looking at for a pair of 570's sli?
  13. 750-800W
  14. Oh Okay. Thanks!
    One more thing though: You think I should wait for Black Friday to order my parts on Newegg for some possible deals?
  15. lnull said:
    Oh Okay. Thanks!
    Not black friday, Cyber monday. Black friday is only for stores, Cyber monday is discounts online
  16. Get a TX750.
  17. I'm getting an TX750M. :P Thanks though.
  18. rule of thumb cpu and mobo should cost around same never cheap out !
  19. Final Build:
    COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
    EVGA 012-P3-1577-KR GeForce GTX 570 (Fermi) HD DoubleShot 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
    CORSAIR Gaming Series GS800 800W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC High Performance Power ...
    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
    Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ..
    LG Black Blu-ray Drive SATA Model UH12LS28 OEM LightScribe Support - OEM
    It's about 1080$ + HDD. I'm trying to find a 1tb for under 100.
  20. Best answer selected by lnull.
New Build Systems Product
