CPU: Intel i7-2700k $369.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115095
GPU: Two EVGA SuperClocked GeForce GTX 570 HD $349.99 each
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130622
Motherboard: GIGABYTE GA-Z68X-UD3H-B3 $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128498
Ram: CORSAIR Vengeance 12GB DDR3 1600 $78.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233146
Hard Drive: Seagate Barracuda 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Power Supply: Rosewill Xtreme Series RX850-S-B $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182072
CD/Blue ray player-burner: LG Black Internal Super Multi Blue with 3D Playback Blu-ray Disc Rewriter $81.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136239
Case: XCLIO Blackhawk Black Finish 0.8 mm SECC / ABS Plastic ATX Full Tower Extreme Cooling Computer Case $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103026
And Windows 7 home addition 64bit
The whole package cost is $1870.90 on newegg.com
Mainly building to play skyrim, BF3, and the mass effect series
Thank you for reading
