CPU: INTEL CORE I3 2100, LGA1155, 3.1GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
MOBO: ASUS P8H67
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131706
GPU :SAPPHIRE Radeon HD 5670
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102871
RAM : any dual-channel 2x2gb mostly...
PSU: looking for advice
I want to play games on mid-max details but not on such a high res. Should i buy the 1GB Radeon 5670? I heard that because it only has 128 bits it doesn't really matter that much if it's 1gb or 512mb. I already have a case and for the moment i want to keep and old HDD which is ATA and that's why i chose that mobo. Any advice/criticism is welcome.
Thank you.
MOBO: ASUS P8H67
Thank you.
