Solved
M61SME-S2 problems
Okay, I was given this motherboard + a CPU which works with the board (Has been running in there for 4+ years), its got 2x 1gb DDR2 ram sticks. I worked out the PSU was failed so I tested it with my TX750 and now it powers on but doesn't give off a image. I have tested on-board and with my 8800 GT XFX and my GA 550 Ti, none of them give off anything. Don't know what the problem is but I think its dead. Any ideas?
Thanks
Nicholas
3 answers Last reply Best Answer
More about m61sme problems
  1. Best answer
    Could be a weak power supply that can't handle your video cards. Also be sure your cards don't need a special lead from the ps such as the 6 pin connector.
  2. I worked it out in the end. Random problem with the cpu not making contact. Everything working fine now. P.S. 750watt is more than enough XD
  3. Best answer selected by mc_creeper.
Chipsets Motherboards
