Solved
Cooler master silent pro m600 watt psu for gtx 560ti or more cards
  • Power Supplies
  • Gtx
  • Cooler Master
  • Antec
  • Components
Last response: in Components
February 21, 2012 12:53:22 PM
guys i have posted about cooler master gx 550 psu vs antec ea500d
in which i got the result to buy antec
now what about this for a psu my pc specs are
i5 2500k,intel dh67cl,4gb ddr3 1333mhz,dvdrw,cooler master elite 370 case
i am buying gtx 560ti will this psu be good ???
it is cooler master silent pro m600watt 80+ and also tell me this is good enough for gtx 570??
http://www.coolermaster.com/product.php?product_id=4199...
More about : cooler master silent pro m600 watt psu gtx 560ti cards
Best solution
a b ) Power supply
February 21, 2012 1:01:35 PM
its well reviewed
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
and the GTX 570 recommends 38a on the 12v rail, the CM has 40a so would it be good enough? yes. would i personally get a bit more power? yes but that is my opinion. the CM 600w will power the GTX570 and obviously the GTX560ti.
February 21, 2012 1:04:03 PM
so is it good stable psu?
m
l
a b ) Power supply
February 21, 2012 1:07:28 PM
yes
m
l
a c 275 ) Power supply
February 21, 2012 7:57:18 PM
The Silent Pro M is a good quality model series.
It would be fine for your specs.
m
l
February 22, 2012 4:48:14 AM
Best answer selected by pell380.
m
l
July 28, 2012 9:56:46 AM
CM silent Pro M600 vs GX 650, which one??
I want to power MSI GTX 560-ti TFII/OC
m
l
