Power switch/Reset switch
bigcheazyofwg said:
Hey guys just got my Asrock z77 extreme 4 and idk if the power switch goes vertically or horizantally. Also dont know about the reset switch and the led's.
Thanks!
Your motherboard manual will have a diagram of your front panel header.
The pwr and rst switches are momentary contact switches, and there is no differentiation of + and -.
Just connect them to the two pins.
The led leads ARE polarity sensitive.
Since there is no standard, try assuming the colored leads are positive.
If the led does not light up, no harm is done, just reverse them.
