Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > HD 6850 Crossfire power consumption question
Forum Graphics & Displays : AMD Radeon HD 6850 Crossfire power consumption question
Im just wondering ; I have got an Radeon HD 6850 with Intel 2500k 4.6ghz overlock, 1 hdd and dvd reader, one ram stick on a 600w PSU.
Is it possible for me to buy another 6850 to run in crossfire or does my 600w PSU put a stop to that?
Reply to Makke
Not safely ;
Guru3D's power supply recommendation:
Radeon HD 6850 x1
On your average system the card requires you to have a 450 Watt power supply unit.
Radeon HD 6850 x2
A second card requires you to add another ~130 Watts. You need a 650 Watt power supply unit.
Reply to robjordy
A 600W PSU will be enough. Last time I checked 6850s in XFire draw from 300W to 400W. With that OC, your system will probably pull more though.
Message edited by AbdullahG on 09-25-2011 at 02:54:38 AM
Reply to AbdullahG
- 0 +
I WANT to think that it will be enough, can't really afford both a new PSU and an 6850.
I did some calculating on http://www.thermaltake.outervision.com/Power, and in load my system will draw 434 watts of power. I may have calculated wrong buy i re-did it three times and got approx the same watts every time 434-450 ish~.
I mean, with 150w left over there shouldn't be any problem what-so-ever, right?
Reply to Makke
First, what 600W PSU?
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
^+1.
PSU QUality is everything.
There's even a guy on Overclocker's forum with a GTX 480 on a Silverstone Strider 430watt
------------------------------ True Malaysia
Malaysian Fact
LittleGreg:Core i5-2500,8GB ddr3,MSI P67A-C45,Sapphire HD6950 1GB,3TB Total HDD,Xigmatek NRP-PC602
Lappy: Athlonx2QL62, 4GB ddr2, HD 3200 IGP
Reply to greghome
Possible I suppose. GTX480 has a TDP of 250W I believe. Round it up to 300 for the board drives and ram. Add in 100W for your normal quad and your looking at 400W for a system. As long as that 430W can do all/most of its power on the 12V rail like most new units can, you can just barely get away with this.
At the same time I can point out several units (Most diablotek units???) that are 500W or more that I wouldn't trust to power a GTX480.
Always a DEMON!
Reply to 4745454b
- 0 +
Corsiar CX600w, i think it has 80+ certification but i'm not sure. I calculated the load power consumption (Load=~90%) to be around 434w, and on the 4 reviews I've looked at the power consumption was from 385w - ~460w. With a 600w PSU there will be 166w over, and that's like.. Totally safe? Sounds safe to me but I'd love to hear your opinions!
Reply to Makke
TDP for the 6850 is 130. x2 = 260 just for the GPUs. Not sure how much you've upped the voltage on your OC'd CPU, so lets say 150W just to be safe. Toss in another 50W for the board, ram, drives, etc and your at 460W.
The CX600 (either version) has 40A on its 12V rail. This comes out to 480W. This is REALLY close to what your PSU can do. You could get away with it, but you'll be putting a lot of pressure on your PSU. I vote do it, but the next upgrade you do is the PSU. Do your best to keep it cool in the mean time, and perhaps dial the CPU OC down as well. No matter what, DO NOT OC the GPUs!
Always a DEMON!
Reply to 4745454b
- 0 +
The overclocked CPU is at 1.35v core so 130w there. So accodring to your calculations it will be, as I've already mentioned, 440w. I had no idea it could only deliver 480w :s. So i got 40 watts over, is it safe? I will not push anything else in, i might even remove a fan if necessarily. Dont think it will make much of a difference but still, i'm willing to do it. Whatcha guys think?
Reply to Makke
It should run, in the event that the PSU is not enough, u would merely experience performance lag or system not booting at most.
it should be ok
Malaysian Fact
Reply to greghome
- 0 +
Any more thoughts?
Reply to Makke
apparently the CX series is overrated http://www.overclock.net/power-sup [...] 0-psu.html It SHOULD be enough still, but its really up to you, maybe run the CPU at stock clocks for now and dont overclock the vid cards. An i5 2500 at stock clocks is plenty for now anyway.
------------------------------ INTEL CORE 2 Q6600 @ 3.49GHz, CM Hyper TX3, ASUS P5N-D, 8GB DDR800 RAM, Powercolour HD6850, 650w Antec Trupower New PSU
Reply to iam2thecrowe
- 0 +
Your PSU actually has 480w on the +12v rail as 4745454b said and that is what matters. The PSU calculators tend to overdo things a bit and you are unlikely to actually ever reach the number it gives you. So it should work but you are pushing the PSU up near its limit. Replacing it with a better PSU at some point would be a good idea, especially if you want to overclock.
Reply to jyjjy
iam2, just because some guys on a forum say its overrated doesn't mean it is. No body provided any links to anywhere I trust that says its the case. The big "problem" with the CX series is unlike the previous gen they aren't as powerful on the 12v rail. The CX500 has as much power as the VX450. (33 or 34 amps for both.) If the CX was to be an improvement it should be able to handle more.
The CX is what I consider to the be Antec's "basiq" line. A cheap PSU from Corsair that can get the job done. Doesn't have tons of power, isn't the most efficient, but using it won't cause your system to blow up.
Always a DEMON!
Reply to 4745454b
- 0 +
What I will do is to buy another 6850 and after a time get a new PSU. After everything I've read here I think that it is safe. I will remove the overclock on my CPU and maybe use the "Power saving" mode on my p67 MB, if that would save me some Watts. What's the worst thing that can happen if my PSU cant handle it? Will it like, send a bolt of electricity trough my system that blows out everything? (In all seriousness, what can I expect if the PSU can't handle it?)
Reply to Makke
Random shut downs when you draw more then your PSU can output. You shouldn't see any voltage spikes, though you could have some out of spec ripple depending on the unit.
Always a DEMON!
Reply to 4745454b
- 0 +
If your PSU can't handle it the system either won't start up or will become unstable, shutting down unexpectedly when it needs more power than the PSU can deliver, most likely during gaming.
Reply to jyjjy
Yeah, random might have been the wrong word...
Always a DEMON!
Reply to 4745454b
- 0 +
But according to my calculations I have 40w over, maybe even a little more if I remove the overclocks and lower fan speeds etc. Will my system be unstable anyways?
Reply to Makke
Probably not. I refuse to say no because dud units exist. You'll be fine, but over time as your unit is stressed you'll have issues. Run it, but upgrade your PSU when you get the chance.
Always a DEMON!
Reply to 4745454b
- 0 +
Will do, thanks everyone for the great answers!
Reply to Makke
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1931 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 6 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
