Will 450w PSU be sufficient for the following:
AMD Phenom II X6 1045
1.5 TB HD
2.0 TB HD
24x DVD RW
2 120mm case fans
Also, is there a limit on the amount of wattage a motherboard can handle. I may want to go to 500 with a better manufacturer.
Also, would a 500w sit the same as my 450 right now? Or does a 500 require more physical space.
1.5 TB HD
2.0 TB HD
24x DVD RW
2 120mm case fans
