B Bobmal Honorable Oct 22, 2012 14 0 10,510 Dec 29, 2012 #1 Would it be safe to do the following?: Turn on power supply by shorting it (green and black wires) Then plug the CPU and motherboard cables into a motherboard. My motherboard isn't turning on (no beeps or anything), so would this be a viable option?
S ss202sl Glorious May 23, 2012 8,431 35 44,190 Dec 29, 2012 #2 Are you asking if you should connect a shorted PSU to your motherboard? The answer is NO. Is this a new build? Upvote 0 Downvote
B Bobmal Honorable Oct 22, 2012 14 0 10,510 Dec 29, 2012 #3 ss202sl : Are you asking if you should connect a shorted PSU to your motherboard? The answer is NO. Is this a new build? I've had it for a little bit, and the motherboard stopped working a few days ago Upvote 0 Downvote
clok555 Honorable Mar 15, 2012 99 0 10,640 Dec 29, 2012 #4 if MOBO stopped working RMA the fudger Upvote 0 Downvote
