I am looking forward to someone giving me advice with this new motherboard I want to buy
I had no reason to upgrade my motherboard, I have a dell Inspiron 518 in Which I have a corsair 430 watt power supply
2 days ago I bought a EVGA GTX 650 1Gb video card, was exited when the item came in but I was let down by my motherboard
I removed my old radeon HD 2400 video card and I uninstalled the drivers, Turned of PC and Plugged in the 650 with the 6 pin adapter.
Video card booted fine into bios up to the point where the windows loading screen was about to come on the signal displayed no output and the motherboard beeped and restarted.
I tought maybe a clean windows 7 install will fix this as Ubuntu works fine with the card
Clean windows 7 install= Same issue
I had to connect my VGA cable to my onboard graphics card to install a fresh windows as when I tried to install with the card on windows installer would restart once windows tried to start to install windows
Same problem came with windows vista
Same problem came with windows xp
So my last resort was that my motherboard was the issue after I called support and the guy told me basically I had done everything to troubleshoot the issue and the problem was with my dell motherboard
Now I went motherboard shopping and I need a LGA 775 socket motherboard and I just hate the low availability for these socket motherboard
Newegg has very few and poor options
Tiger direct as well
PC Geeks only has 7 options of which 5 options are defualt green intel motherboards
After long search I saw ebay had a bit more availability of motherboards
http://usa.asus.com/Motherboards/Intel_Socket_775/P5G41M_LECSM/
motherboard cost 70 dollars which I am OK with but my friend just did a new AMD build socket AM3 and his motherboard a Gigabyte motherboard cost him 50 dollars and he has double the features and Fancy GUI BIOS
Anyways I just want to make sure that if I buy this motherboard I wont have any similar Issues with it
If anyone can point me to a different retailer with more options please do tell me
I need the board to be compatible with DDR2 ram that's why my search gets just more narrow
thanks for any of your help and thanks also If you have read up to here
Its a very long story I typed here
