I recently upgraded my GPU from a 5770 to an evga 560ti 448 cores classified. I had to connect another 6 pin lead to my power supply in order to power the new card.
Now, when I turn on my computer, a fan spins really loudly, then stops spinning, and then everything is normal again. It boots perfectly fine into WIndows, and I have not had any errors whatsoever. I haven't done anything else to the system, and I checked all the connectors to see if they are in place. Is this something to be worried about ?
I checked the wattage draw, and it's way below what my psu can handle.
Full system specs:
Gigabyte GA-P55A-UD3R
Intel Core i5 750
EVGA GTX 560ti 448 cores classified
Hitachi 1TB HDD
OCZ ModXstream pro 500W
Asus Xonar DG
Antec 300
Thanks for your help !
Full system specs:
Intel Core i5 750
Hitachi 1TB HDD
Asus Xonar DG
Antec 300
