CPU Coolers Xigmatek Loki SD963 or Arctic cooling freezer pro 7
Last response: in CPUs
Hi all
just wondering if anyone knew which of these would be better for overlocking and keeping low temps. Also a quieter one would be great. Please let me knwo which is better. would be much appriciated
thanks
Jake
thanks
Jake
The Loki cools a bit better and the AC Freezer 7 Pro is just a bit quieter at full speed.
Either one would be a reasonable choice for a smaller case if you can't fit a 120mm fan sized cooler.
Xigmatek Loki SD963 Mid-Compact Heatsink Review
Arctic Cooling Freezer 7 Pro Rev. 2 CPU Cooler Review
Related ressources
- Xigmatek Loki vs Arctic Cooling Freezer 13 vs Scythe Rasetsu - Forum
- Tuniq Tower or ARCTIC COOLING Freezer 7 Pro - Forum
- Q6600 and Arctic Cooling AC-FRZ- 7 P Freezer 7 Pro - Forum
- Arctic Cooling Freezer 7 Pro or Xigmateck HDT-S1283 - Forum
- Arctic Cooling Freezer 7 Pro any good? - Forum
XIGMATEK Gaia SD1283 will perform better than Loki or Freezer 7 Pro. And the bigger 120mm fan should stay running slower, longer, to keep it quieter as well. Even at full speed the fan is quieter than the other two.
Xigmatek Gaia SD1283 Heatsink Review
Here is the case, i think it says 19cm width
http://www.novatech.co.uk/products/components/cases/cas...
I'd go with the Arctic Cooling Freezer 13. = 130mm tall and will fit in your case(7.48" W) for sure.
http://www.play.com/PC/PCs/4-/20934052/-/Product.html?s...
Cooling performance looks very good from this review.
http://www.legitreviews.com/article/1609/6/
davcon said:
I'd go with the Arctic Cooling Freezer 13. = 130mm tall and will fit in your case(7.48" W) for sure.http://www.play.com/PC/PCs/4-/20934052/-/Product.html?s...
Thanks, it looks a good alternative if the other will not fit, will the performance be significantly affected, (sound etc) without a 120mm fan?
thanks
I just noticed, the link you send me for the cooler was for the Freezer 13 whereas the review was showing results for the Freezer 13 PRO which is larger and more expensive.
thanks anyway
jakedavies8 said:
Thanks, it looks a good alternative if the other will not fit, will the performance be significantly affected, (sound etc) without a 120mm fan?thanks
Nope it performs quite well noise wise.
http://www.xbitlabs.com/picture/?src=/images/coolers/ar...
jakedavies8 said:
I just noticed, the link you send me for the cooler was for the Freezer 13 whereas the review was showing results for the Freezer 13 PRO which is larger and more expensive.thanks anyway
Don't worry too much Xbitlabs tested both and the regular one performed basically the same thermally.
It's a far better value then the PRO model.
just wanted to put my support behind the Xigamtek Gaia, I have one in my pc and keeps my stock 2500k very cool, and when i do overclock i'm expecting good things:
http://www.eteknix.com/reviews/cooling/xigmatek-gaia-sd...
http://www.hardwaresecrets.com/article/Xigmatek-Gaia-CP...
http://www.clunk.org.uk/reviews/xigmatek-gaia-sd1283-cp...
All this performance for £17 is amazing, and as the hyper 212 is so expensive now (used to be about the same) probably the best performance per pound on the market.
Arctic Cooling Freezer 13 Heatsink Review @ FrostyTech
It looks like the Freezer 13 sits between the Loki & AC Freezer Pro 7 and Gaia in both cooling performance and quietness.
Gaia on its low fan setting cooled just slightly better than Freezer 13 and was quieter by 34.9 to 48.5 dBA. (you'll need to look at the Gaia review of find the data for both)
One last thing to consider - the way the coolers are mounted.
Gaia will need the motherboard removed to mount the backing plate while Freezer 13 can be installed without removing the motherboard.
Looks like the Xigmatek is both cooler and quieter to me.... but £1 more expensive
http://www.frostytech.com/articleview.cfm?articleid=259...
Hi all,
Just thought I'd let you all know that in the end I went for the Freezer 13. Purely because I don't think the other ones would fit in my case very well. I also liked the mounting system on the freezer as I Don't want to remove my motherboard. Thanks for all the advice offered, I appriciate you all taking the time to help.
Regards
Jake
Regards
Jake
Related ressources:
- ForumIs Arctic Freezer 7 Pro good for Quad core CPU ?
- ForumNeed replacement cooler (Phenom II X4 955)
- ForumHeatsink
- ForumArctic cooling freezer 7 pro rev.2 - CPU FAN ERROR
- ForumQ8400 Overheating
- ForumZEROtherm 92mm Silent CPU Cooler vs ARCTIC COOLING Freezer 64 Pro
- ForumCooler Master Hyper 212 Plus Vs Arctic Cooling Freezer 7 Pro Rev.2
- Forum1100T Stock vs Arctic Cooling Freezer 64 Pro
- Forum212 evo fan replacement
- ForumNew GPU and old CPU questions
- Forum[Solved] Which Prog. is telling wrong CPU temp.
- Forum[Solved] My CPU Temps risen 20 degrees after installing new CPU e8500? Normal?
- Forum[Solved] AMD Athlon ii x4 645 Cooling
- ForumCPU
- ForumCPU Heatsink ADVICE NEEDED
- More resources
