2 sound cards?
Forum CPU & Components : Sound Cards - 2 sound cards?
i currently have the SB live x-gamer and would like to get another one so i can use my mixer with my computer. (two winamps, one card for each insance of winamp) is this possible? i was thinking i should get a phillips or something else so the chips don't have the same name? i would prefer to get the 5.1 platnium.
thanks for the help :)
Sponsored Links
This was discussed one week ago, http://forumz.tomshardware.com/har [...] =5319#5319
pill128
Take your pill, and get some sleep.
Reply to Anonymous
- 0 +
sorry, i should have been more specific. i know i can have 2 sounds cards but can i have 2 SB live cards in the same machine? one x-gamer and one platnium 5.1. i have heard that the drivers may not be able to decipher which card is which or something to that effect
Reply to icey0
- 0 +
well i have to 2 video cards running 2 monitors in win98. I have Savage4 + ATi radeon 32mb ddr. talk about weird combo.
First person to get a topic banned. ABIT BP6 Lives FOREVER!!!
Reply to rcf84
To my knowledge the actual card itself is the same, the Platinum just comes with the Live Drive, the X Gamer comes with other stuff, but the actual physical Creative Labs SB Live is identical... so why, why would you want to put to in the system? They have two outputs for 2 sets of speakers, I don't get your need for two cards.
Reply to Anonymous
- 0 +
i have a mixing board for dj'ing. i will have two winamps open at the same time. one winamp is configured for one sound card, the other winamp is configured for the other sound card. this way i can have the output of the first winamp going into channel on my mixer and the output of the second winamp going to the other channel on my mixer. this way i can fade, change the pitch, etc of an output while it is not playing (and the other is playing).
the reason i would like to have 2 SB live cards in the same machine is so i can have the live drive and that sweet remote :) (i currently have the x-gamer)
will the drivers and the os not be able to handle having 2 identical sound cards?
kn7671: i need two cards because i need two different sources(the two winamps). if i plugged in two speakers to the one card i would get the same source
thanks for your interest and help :)
Reply to icey0
Never tried two cards before, but have had an on-board sound with a internal card as well, and both worked at the same time, but as for two identical cards that the system uses could pose a problem. One instance I could think of would be that when you go to choose the source for sound input or output, Windows would list the same device twice, unless it lists SB Live #1 and SB Live #2. Try it and let us know.
Reply to Anonymous
i'm not sure if you'll have a problem with 2 lives, but i have a sblive and awe64 with no problems. my inclination is that since they'll be on different IRQ and in different PCi slots you should be able to use two identical sound cards. but that's just a hunch.
Reply to Anonymous
Tom's Hardware > Forum > CPU & Components > Sound Cards > 2 sound cards?
There are 595 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
