Will these parts work together?
I am currently building my own computer for my university course and gaming that I do. My course requires some serious rendering software.
Will these parts work together:
Motherboard ASUS Crosshair V Formula 990FX Socket AM3+ 8 Channel audio ATX Motherboard- http://www.ebuyer.com/270700-asus-crosshair-v-formula-990fx-socket-am3-8-channel-audio-atx-motherboard-crosshair-v-formula
Processor AMD Bulldozer FX-8 8150 8 Core 3.6Ghz Socket AM3+ 8MB L3 Cache 125W Retail Boxed Processor- http://www.ebuyer.com/287680-amd-bulldozer-fx-8-8150-8-core-3-6ghz-socket-am3-8mb-l3-cache-fd8150frgubox
Memory Corsair CMZ16GX3M4A1600C9B 16GB (4x4GB) 1600MHz CL9 DDR3 Vengeance Blu Memory Four Module Kit- http://www.amazon.co.uk/Corsair-CMZ16GX3M4A1600C9B-1600MHz-Vengeance-Memory/dp/B004RFBIUU/ref=sr_1_35?s=computers&ie=UTF8&qid=1321999657&sr=1-35
Graphics XFX HD 6950 DD 2GB DDR5 Dual DVI Dual DisplayPort HDMI PCI-E Graphics Card- http://www.ebuyer.com/285982-xfx-hd-6950-dd-2gb-ddr5-dual-dvi-dual-displayport-hdmi-pci-e-hd-695x-cddc
Hard Drive Seagate 3TB 3.5" SATA-III 6Gb/s Barracuda XT Hard Drive - 7200RPM 64MB Cache- http://www.ebuyer.com/260677-seagate-3tb-3-5-sata-iii-6gb-s-barracuda-xt-hard-drive-7200rpm-64mb-st33000651as
PSU XFX Pro 850W Core Edition PSU - Single Rail 9x SATA 4x PCI-E- http://www.ebuyer.com/241548-xfx-pro-850w-core-edition-psu-single-rail-9x-sata-4x-p1-850s-ukb9
10 answers Last reply
More about will parts work together
  1. I would recommend you look into the motherboard, and see if it supports HDDs that are that large. I know some motherboards won't support any HDD over 2TB. You are also missing the case, and DVD/Blu-ray drive, which you need, unless you have you're using your old one
  2. Now is not the time to be buying HDs, especially 3TB ones. You're talking over $450 for a single drive alone. :ouch: :ouch:
    I'd cut the HD down to a 1TB and invest that money elsewhere - particularly case, PSU, and optical drive or monitor.
  3. Yeah im not entirely sure I want a HDD that big anyway, but here is the case I just bought and the Blu ray drive im just about to place an order for
    Case
    http://www.ebuyer.com/240815-nzxt-phantom-white-full-tower-case-phan001wt
    Blu Ray
    http://www.ebuyer.com/195145-lg-bh10ls30-10x-bd-re-with-dvd-rw-sata-blu-ray-drive-retail-box-bh10ls30-auar
    or maybe the HD Radeon 6970?
  5. Is that instead of the graphics card I have in there already?
  6. Yes, that is to replace the one you should buy. The one you had was the 6950, the one I chose is the 6970.
    http://www.ebuyer.com/280423-powercolor-hd-6970-2gb-gddr5-dual-dvi-dual-mini-displayport-hdmi-pci-e-ax6970-2gbd5-2dh
  7. thanks might reconsider the hard drive and use the saving to get the better graphics then
  8. What about this for a hard drive?
    WD 1TB 3.5" SATA-III 6Gb/s Caviar Black Hard Drive - 7200rpm 64MB Cache-
    http://www.ebuyer.com/193712-wd-1tb-3-5-sata-iii-6gb-s-caviar-black-hard-drive-7200rpm-64mb-wd1002faex
  9. that works
    Case
    Blu Ray
    Good choices - love the Phantom and the LG Blu Ray burner that I just bought seems to work pretty well for the most part.
    I like that choice.
New Build Systems
