Help finalize my build? $800
Approximate Purchase Date: Cyber Monday
Budget Range: 800 after rebates
System Usage from Most to Least Important: Gaming, movies, light video editing.
Preferred Website(s) for Parts: newegg.com ncix.com
Parts Not Required:I don't need a hard drive, peripherals, OS, or monitor. just the essentials
Country: US
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: 1680x1050 or 1920x1080
Additional Comments: Thanks to those who responded to my last set up. I have decided to go for the i5 2500k from the fx-4100 :] after a few revisions this is what I have came up with. As stated above, I just need the essentials
comes out to $820 at check out $760 after rebates
Cooler Master Scout + COOLER MASTER Silent Pro M600
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.761977
Intel i5 2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
ASRock Z68 Extreme3 Gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
2x4gb Rip jaws (1600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
MSI N560GTX-TI Twin Frozr II
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127565
2 answers Last reply
More about help finalize build
    Country: US
    Overclocking: Yes
    Intel i5 2500k
    This may be unhelpful, but for my enlightenment, is that PSU enough to handle everything, namely your video card. It requires quite a bit of juice.
  2. Hmmmm... I didn't really take that into consideration
    I was thinking about
    a corsair 750
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021&Tpk=corsair%20750
New Build Cooler Master Systems Product
