I was wondering, what Power Supply might work with the Pavillion a6342p case model? I was looking at around the 400 watt range, and the current Power Supply is the default 250 watt one.
Would this possibly work, or should I stick with your suggestion? Just trying to test my horizons before choosing. http://www.amazon.com/Antec-EA-380D-Power-Supply/dp/B002UOR17Y/ref=cm_cmu_pg__header
Possibly even this.
http://www.amazon.com/Antec-Green-Energy-Efficient-Supply-EA500D/dp/B002VLYKDO/ref=sr_1_3?s=electronics&ie=UTF8&qid=1330072130&sr=1-3
Yep both very good units.
The unit i suggested has 34A on the +12V and a 5yr warranty.
