NZXT Apollo case, help?
I was wondering if anyone has used the NZXT Apollo mid tower before because I was hoping they could tell me what kind of cable management it has. I'm thinking about buying it...but aesthetics are very important to me for my builds. THANKS!
2 answers Last reply
More about nzxt apollo case help
  1. The case don't have holes for cable management,it will be a little hard to do a good cable management. I recomend you CoolerMaster 912. they are at same price.CM 912 is very good for cable management and you can put inside her the bigest video cards available on the market , and another plus for CM is the air cooling of the case.
  2. An opaque side panel is a necessity for me. Like I said, I feel very strongly about aesthetics for my builds.
Homebuilt Cases Management Cable Systems Product
