Solved
Power Supply For NVIDIA GTX 560?
  • Power Supplies
  • Gtx
  • Components
  • Product
Last response: in Components
February 24, 2012 3:39:14 PM
Hello,I was looking to upgrade my power supply for my GTX 560. I already have picked out two power supplies for me to look into consideration,but was wondering what the Tom'shardware community thought first:)  Ill have the links and my pc specs below;
My specs;
Mainboard : ASRock M3A770DE
Chipset : AMD RD770
Processor :AMD Phenom II X4 955e @ 3200MHz
Physical Memory :8GB(DDR3-SDRAM )
Video Card : NVIDIA GeForce GTX 560
Hard Disk : Seagate (500GB)
A little later on I plan on over-clocking my CPU,so I'm not sure if that'll increase my wattage needed. Thanks in advance for any replies,recommendations,and helpful tips.
More about : power supply nvidia gtx 560
Best solution
a b ) Power supply
February 24, 2012 4:16:28 PM
Buy Corsair TX 650W is 80+bronze certified.
a b ) Power supply
February 24, 2012 4:20:20 PM
I like the enthusiast series better.
m
l
February 24, 2012 6:23:32 PM
So,the enthusiast series Corsair is good enough for my GTX 560 and when i OC my CPU?
m
l
a c 86 ) Power supply
February 24, 2012 7:26:17 PM
With ease.
m
l
a c 111 ) Power supply
February 24, 2012 7:27:06 PM
It even has enough for 2 560's.
m
l
February 27, 2012 2:38:11 AM
Well,thanks for all of the replies. I was pretty sure that the TX650 would be better,but I had to be positive that i was making the right choice.
m
l
February 27, 2012 2:38:47 AM
Best answer selected by Anthony1025.
m
l
