Help on case and mobo plizs
Last response: in Memory
Yes. It will fit. If the board is labeled atx or micro-atx, then it will mount in your corsair 650d-case. Be sure to inspect the case standoffs for position and be sure they're all tight; remove any extras that aren't needed, and also make sure the backplate is straight (square) when you install it inside the case.
