Closed Solved
First build advice
Approximate Purchase Date: This week, hopefully Black Friday/Cyber Monday
Budget Range: $800-$1000
System Usage from Most to Least Important: Gaming
Parts Not Required: Keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country: U.S.
Parts Preferences: Intel, Nvidia
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
First time builder here, looking for some advice. I don't really have much hardware experience, but hope to be able to accomplish my first build with online guides/videos.
I came up with a list of parts on newegg.com, let me know what you think and would change. As I said, I'm a complete newb at this, so let me know if I made a rookie mistake like picking incompatible parts. Also, is there anything else not listed that I need? Thanks for all the help.
Processor: Intel Core i5-760 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.762393
Motherboard: BIOSTAR TPOWER i55 LGA 1156 Intel P55 ATX Intel Motherboard
Case: XCLIO A380COLOR Fully Black 1.0 mm SECC / ABS Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103033
Video Card: EVGA 02G-P3-1559-KR GeForce GTX 550 Ti (Fermi) 2GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130652
Power Supply: CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
RAM: G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231315
HDD: SAMSUNG EcoGreen F2 HD103SI 1TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152173
Heatsink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Optical: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
5 answers Last reply Best Answer
More about first build advice
  1. The 1156 platform is last gen. If you are looking for a full build ground up, it doesn't make any sense to go that way any more. The following build is gonna be so much faster for the same price-
    CPU: $215 Intel Core i5-2500K
    Board: $100 ASRock Z68 PRO3 - You may save ~$50 odd on the CPU+Mobo if you don't want overclocking. But keeping that option open is worth it IMO.
    RAM: $45 G.SKILL Ripjaws Series 8GB
    HDD: $95 Western Digital Caviar Blue 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s. I'm trying hard not to recommend 320GB drives at $100 :ouch:
    GPU: $350 EVGA SuperClocked GeForce GTX 570
    HSF: $25 COOLER MASTER Hyper 212 Plus
    ODD: $20 Samsung DVD+-RW with Lightscribe-OEM
    Case+PSU: $70 Shell Shocker: Antec Neo Eco 620+Antec 300
    Total: $920 (After rebates) Plus shipping. Get the Shell shocker combo now and check the PSU immediately in a current system of yours or a friend's.
  2. Adjusted a few things, due to feedback and some parts being sold out. Trying to finalize my order today. Please let me know if there are any compatibility issues with the list below, or any final changes I should make.
    CPU: Intel Core i5-2500K
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
    Board: ASRock Z68 PRO3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157251
    Video Card: GeForce GTX 550 Ti (Fermi) 2GB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814162079
    Power Supply: Antec NEO ECO 620C 620W Continuous Power
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
    RAM: G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231312
    HDD: AMSUNG EcoGreen F2 HD103SI 1TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5"
    Optical: Samsung DVD+-RW with Lightscribe-OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151243
    Thanks for the feedback.
  3. Best answer
    1. RAM: Drop the RAM down to 8GB. Gaming barely needs 4. You won't see any performance gain from 16. The kit in my link will do great. It's also faster than the one in your link.
    2. HSF: You need aftermarket HSF only for OC'ing. Since you don't intend to do that, drop it. The stock Intel HSF should be plenty good even for minor overclocks. Don't even bother with the aftermarket one.
    3. HDD: $60 Seagate Barracuda 500GB - Much faster 7200RPM SATA 6Gb/s drive. The one in your link is a slower 'green' 5400RPM SATA 3Gb/sdrive. Wait for this $80 SAMSUNG Spinpoint F3 1TB drive to re-list if you want a 1TB drive.
    4. GPU: Your budget can easily fit at least a GTX 560ti. You'll see better performance and better longevity from that especially at 1920X1080 - $230 (After rebate) EVGA AR GeForce GTX 560 Ti - with lifetime warranty.
    5. PSU: Since you're not going with the GTX 570, it makes no sense to go with an overkill $75 620 watt PSU for the 560ti. This $55 Antec NEO ECO 520C 520W will do just fine.
    CPU: $220
    Mobo: $100
    RAM: $45
    HDD: $60
    ODD: $20
    GPU: $230
    PSU: $55
    Case: $100
    Total: $810+Shipping (After Rebates). Well within the lower end of your stated budget, yet much faster. I had listed the GTX 570, because that would have cost you $120 more and it would have still been well within the 1000 dollar budget cap (~$930).
    PS: If you're sure you really don't want to overclock, you can decrease your expenditure even further without taking any performance hit whatsoever.
  4. Best answer selected by bhawk26.
  5. Cheers :)
New Build Systems Product
