System I Would Like to Build
For the money, this is damn near the best system I can come up with.
I want to be certain that all the parts are compatible and will run smoothly!
What do you think?
Asrock (970 EXTREME3) ATX AMD 970 85.00
DIAMOND Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 - OEM 70.00
AMD Phenom II X4 925 Deneb 2.8GHz Socket AM3 95W Quad-Core Desktop Processor HDX925WFK4DGM - OEM 90.00
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL 30.00
Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case 40.00
ePOWER EP-500NE-XV 500W ATX12V v2.2 / ESP12V v2.91 Power Supply - OEM 30.00
Western Digital Caviar Blue WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive 110.00
Total: 455.00
5 answers Last reply
More about system build
  1. I'm assuming your budget is $450, but I'm not sure...If you can tell us your budget, it'll let us help you more.
    CPU: AMD Phenom II X4 955 $125
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
    Graphics: HIS H679F1GD Radeon HD 6790 $130
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161377
    MoBo: Foxconn M61PMP-K AM3 $45
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813186189
    PSU: COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W $40
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171031
    Case: NZXT Gamma $36
    http://www.amazon.com/GAMMA-Classic-Interior-Chassis-Black/dp/B002UDK9U6
    HDD: WD 320GB HDD $70
    http://www.bestbuy.com/site/Western+Digital+-+320GB+Internal+Hard+Drive+for+Desktops/7821985.p?id=1142294266836&skuId=7821985
    RAM: G.SKILL NS 4GB DDR3 1333MHz $21
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
    Heatsink+Fan: STOCK $0
    DVD-ROM: SAMSUNG CD/DVD Burner 22X $16 (regular $19, if you miss black friday shopping on Newegg)
    Total: $486
  2. That looks like a beautiful pc. The only issue I have with it is the Micro motherboard. I much prefer the one I have.
    It looks like you took a lot of time doing this! I really appreciate it!
    I'm just browsing. It's not much of a budget thing, but in the near future I'm going to start getting parts for something I can be proud of!
  3. BobbySK,
    Just bought same mobo, it's AM3+ so offers upgrade path, go with it.
  4. From what I know, aren't micro motherboards slower? I intend to game with it, obviously.
  5. m_ATX motherboards are NOT slower , but that foxconn with an nVidia chip set is going to perform well as a paper weight or door stop
    Stick with the 970 Asrock
    use only 2 x2 gig of RAM
    fit an Athlon X3
    and the best graphics card you can afford . 6770/6790/even 6850
Homebuilt Systems Product
