Solved
Help with Eyefinity
if i have dual xfx 6950 can i run 3 monituers using only the dvi
4 answers Last reply Best Answer
More about help eyefinity
  1. Best answer
    If the primary card has x3 DVI ports then yes.Otherwise your going to need a Mini-Displayport to DVI adapter.You can only use the top card(primary) for monitor connections.
  2. Best answer selected by flamingxeno.
    thanks for the help
  4. Welcome
Graphics Cards DVI Graphics
