Here's the story. I built this computer a while back and from the start I've had stability issues. I figured it was the overclocking so I reset everything to default. The computer would often crash after just 10 minutes of starcraft 2 or after about 30 min of battlefield 3. I took it apart, made sure all connections were solid, updated all drivers, ran a smart scan of the hard drive and even flashed my bios. As far as stability, I think I've seen some improvement. However, the pc still lags, especially in battlefield 3. I can only get about 17fps average on the lowest settings.
here are my specs:
Gigabyte ga-ma785gmtud2h mobo
athlon II X2 dual core @ 3ghz
500gb WD green hd
500watt earthwatts power supply
6gb of kingston hyperx ram
zotac geforce9800 gt 512mb
20inch acer widescreen monitor, 1600x900 native resolution
I was under the impression that this rig could run BF3 at higher settings, and certainly run the lowest settings without lag. please correct me if i'm wrong.
I ran speed fan after 30min of bf3 (now that stability issues may have been solved)
the temps shown were:
GPU 49
Core 57
HD 33
temp1 34
temp2 69
temp 3 61
If you guys have any input that would be most appreciated, thanks!
here are my specs:
500gb WD green hd
GPU 49
Core 57
HD 33
temp1 34
temp2 69
temp 3 61
