HELP!! im clueless......graphics, and psu upgrade help
Hello, im kinda in a jam, i have no idea how to upgrade my grapics cad, and wether or not i will need to upgrade my Psu as well. this is my comp
http://www.pacificgeek.com/product.asp?c=220&s=1519&ID=875492&P=F.&GN=1 and these are the graphics cards im thinking of buying http://www.newegg.com/Product/Product.aspx?Item=N82E16814102871 , http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315 i could really use some input on how i should build it up. Also, it would be awesome if u could give me some advice on the correct items to buy if they eed to be upgraded, or if you can think of a better card. My Budget on cards is $50-$100 and same goes for any upgrades. Help would be appreciated, i will return help with hugs and rainbows = D
2 answers Last reply
More about help clueless graphics upgrade help
  1. OOOOOOHHH!! but i dont have windows 7 i have vista >.>
  2. I would go with the 5670. Same price but newer.
Graphics Cards Graphics Product
