POwer Supply Seasonic or Corsair
Power Supplies
- SLI
- Corsair
Components
Last response: in Components
pratmodi
February 26, 2012 10:10:27 AM
cyansnow
February 26, 2012 10:23:19 AM
- What about Thermaltake, Seasonic, Corsair, and Antec power supply? - Forum
- PSU HELP: Seasonic S12II 620W 80PLUS Bronze or Corsair CX600 80Plus Bronze Power Supply - Forum
- Seasonic verses Corsair power supplies - Forum
- EVGA or SeaSonic Power Supply? - Forum
- Seasonic G360W Gold Power Supply - Forum
theconsolegamer
February 26, 2012 10:49:07 AM
bwf1975
February 26, 2012 10:51:28 AM
Seasonic, they make many others and their own, that corsair is made by someone else with corsair adding some protection elements to it, the oem is rumoured to be Channel Well, i've never heard of them, and corsair have not been in the business anywhere near as long as Seasonic.
There's not a lot in it to be honest, not enough to say either way.
m
l
13thmonkey said:
Seasonic, they make many others and their own, that corsair is made by someone else with corsair adding some protection elements to it, the oem is rumoured to be Channel Well, i've never heard of them, and corsair have not been in the business anywhere near as long as Seasonic. There's not a lot in it to be honest, not enough to say either way.
Not a rumor, the original TX850 was CWT built ( think Thermaltake )
The new TX850V2 is Seasonic built.
Corsairs psu reputation was built using products from both oems.
m
l
paragsinnarkar007
February 26, 2012 11:57:58 AM
redeemer
February 26, 2012 2:08:59 PM
No they don't. There are many Corsair units that are built by Channel Well Technologies(CWT), the AX 1200 is built by flextronics. The Corsair 850 TX is based on the CWT PSH platform, the TX-C is the CWT PSH II, the TX V2 is the SS-***HT platform just like the XFX non-modular units. The efficiency is a bit lower but the layout is identical. The TXM series is CWT built too.
Now can we stop the misconception that Corsair units are Seasonic built when they have only ever had 13 models built on seasonic platforms and 25 built on CWT platforms?
m
l
pratmodi
February 28, 2012 9:33:15 AM
Quote:
Seasonic gets my vote, both are excellent manufacturers.the Seasonic is 80+ (silver) and the Corsair is just 80+...
Seasonic.
Yeah i thought about 80PLus Silver certi. in seasonic and corsair TXV2 has 80 plus bronze, but i m still confused about both,i thinkn ishould get seasonic
but is it as good and reputated as Corsair? please reply
m
l
beside efficiency, bla-bla-bla...and other stuff else..
..silver certification, means you can pull power more than bronze one..
850 watt bronze psu (maybe) can deliver 1 kw to, but under 80+ efficiency..pull little more and rail will be horribe..or shutdown (depend on ocp)
850 watt silver psu can deliver 1kw power in bronze efficiency.. pull little more and (maybe) still work, but under 80 effeciency.
m
l
Quaddro said:
beside efficiency, bla-bla-bla...and other stuff else....silver certification, means you can pull power more than bronze one..
No, it doesn't.
It means that it will pull slightly less AC power ( ~3%) from the wall to provide the DC power that the PC needs.
m
l
Best solution
delluser1 said:
No, it doesn't.
actually yes it does..
usually in good brand psu, it can deliver more than the label (depend on the limiter of course).
for the example:
seasonic ss750 js can deliver almost 950 watt before shutdown.
superflower platinum 550 watt can deliver 700 watt continous power with gold effeciency..
a good 80 bronze psu, can deliver (usually) around 100 watt or more than then label before the rail became fail and full of spike/ripple.
80 silver / gold / platinum psu, actually an bronze psu with underrated wattage in order to reach high effeciency..
that's why, you can pull more power from it to feed your system.
but once again, it depend on psu limiter..
for the example:
No, it doesn't
What a power supply can provide in overload tests has nothing to do with efficiency ( it does show the quality of the components ) and is not what any psu purchase should be based on
The ratings are there for a reason, the psu might have gone out of spec, might not have reached the efficiency level , whatever, the higher efficiency rating doesn't mean that it can provide more power
m
l
delluser1 said:
No, it doesn'tWhat a power supply can provide in overload tests has nothing to do with efficiency ( it does show the quality of the components ) and is not what any psu purchase should be based on
yes it does...
all good psu can deliver power more than the label..bronze, silver, platinum, diamond....
depend on limiter on it..
higher component quality, newer technology, newer design, provide more breathe for the system to work out of specification.
and since silver certification usually has higher component quality and better design than bronze, you can pull it more..
like i said before..
superflower 550 platinum can deliver 700 watt with gold efficiency and with good rail on it.
coolermaster gx550 80+, when you try to pull 550 watt on it, it will give you horrible rail output..
seasonic 400 fanless gold can reach 550watt output with good rail.
fsp saga 400 have to struggle very hard even to deliver 380 watt before fail..
you cannot simply judge a platinum psu has the same power with a bronze psu with only difference of 10% efficiency between them.
platinum/gold/silver psu actually is a underrated psu in order to reach higher effeciency..
m
l
I made a resolution to not argue with noobs, last post on the subject
Bronze rated Corsair TX750V2
http://www.hardwaresecrets.com/article/Corsair-TX750-V2...
Silver rated Seasonic S12D 750
http://www.hardwaresecrets.com/article/Seasonic-S12D-75...
OMG, you were right, the Seasonic provided almost 6 watts more than the Corsair
You've got aways to go.
m
l
Quaddro you would do best to reread the terms of use before you go spouting off incorrect information. Double check your "facts" elsewhere because you have quite a bit wrong.
http://www.tomshardware.com/terms.html
The overload tests tell you what a new unit can do, not how long it can do it for, it is not a sustained rating and treating it as such will end disasterously for the power supply long before its due time as you are running the outputs much higher than they were designed to sustain, they have some headroom built into them initially so as they age they can still do the rating over the long run, but a 1 year old unit will not be able to perform the same in the overload test as a brand new unit.
The cooler master GX 550 W in that example is a horrible reference, the GX series is utter crap, only the GX 450 passed a review. If we compare to the Corsair HX 620 instead of a unit that fails before even getting to max load, you can see that even though it is only 80+ basic rated it can still do 120% of max load within spec.
http://www.hardwaresecrets.com/article/Corsair-HX620W-P...
Also, your arguement about platinum/gold/silver units being underrated units to reach higher efficiency is BS, a bronze rated unit will never reach the 90% efficiency at any load level necessary to be a gold rated unit. There are some cases of gold rated platforms being dropped down an 80+ level so they can expand the platforms capacity by 100W, but first you have to have a platform capable of high efficiency.
In both cases, you pick a pretty crappy unit to compare it to simply to prove your point, not to provide accurate information which is wayyyy more important. There is nothing wrong with being wrong, as long as you admit it and learn from it, but don't keep posting bad information on the forums.
Give me enough time and I can select an appropriate sample to show anything I would like, it doesn't mean that what the results show is true, it means im good at lying with statistics(BTW good book read it if you haven't).
Now, lets try to keep things true and factual instead of drawing inappropriate conclusions from tests that weren't meant to provide them.
Quote:
You agree not to post or transmit material that is knowingly false and/or defamatory, misleading, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening or invasive of a person's privacy; that otherwise violates any law; or that encourages conduct constituting a criminal offense.The overload tests tell you what a new unit can do, not how long it can do it for, it is not a sustained rating and treating it as such will end disasterously for the power supply long before its due time as you are running the outputs much higher than they were designed to sustain, they have some headroom built into them initially so as they age they can still do the rating over the long run, but a 1 year old unit will not be able to perform the same in the overload test as a brand new unit.
m
l
Alyus
February 28, 2012 2:35:13 PM
delluser1 said:
I made a resolution to not argue with noobs, last post on the subjectwooowww... you're a super expert then..
hail the (super) expert..
have you ever heard about protection..?
the power limiter inside psu to prevent it burn or blow..?
that's why i always write it with italic...depend on limiter on it..
if you detached this component and test it, there are will be different result of it...
OMG, i forgot, the post above is your last post
@hunter315
okay you're the boss
but honestly, i think i dont post or transmit material that is knowingly false ,misleading, inaccurate or else..
just post based on my experiences on many psu..and bla bla bla (too lazy to explain)
can't wait for your appropriate sample...
that's all...
proceed to another thread...
m
l
pratmodi
February 28, 2012 4:50:21 PM
- Solvedwhich is a better power supply SeaSonic G-750 750W or Antec High Current Gamer 750W ? Forum
- SolvedSeasonic Power Supply capable of handling ten hard drives? Forum
- SolvedMSI R9 280X GAMING 3GB with SEASONIC M12II BRONZE 620W POWER SUPPLY Forum
- SolvedATI HD7770 + Seasonic power supply 750W Forum
- SolvedUPS questions, for use with a Seasonic 850 watt Platinum power supply. Forum
- seasonic m12II power supply Forum
- Is the Seasonic 620W Power Supply is enough for R9 280x? Forum
- Solvedseasonic power supply Forum
- Is Cooler master haf x full tower will fit with power supply SEASONIC Platinum 1000W Forum
- SolvedSeaSonic Power Supply Confusion. HELP PLEASE! Forum
- Can the SeaSonic X-1250 power supply handle my rig? Forum
- seasonic x 750 power supply question Forum
- SolvedSeaSonic Power Supply Swap Out Questions Forum
- SeaSonic s12G power supply fan not working Forum
- I7-4930k and my Seasonic 860W power supply Forum
- More resources
Read discussions in other Components categories
