SO I am trying to figure out what I should do and need some help. Here is my PC specs.
AMD 970 3.5 Ghz
Asus Sabertooth 990fx MoBo
G.SKILL Sniper Series 8GB DDR3 1866
Sapphire Tech 6950 2GB Toxic
Antec High Current Gamer Series 900watt
D-Link DWA-525 Wireless N 150 Desktop Adapter
The question I have is that I am currently using a pci wireless card in my config. I had to remove my sound card as it was also a pci card. Below is the sound card I bought. I bought both as part of my first build. I have learned a bit more since then on what I should buy and to ask questions if I am not 100% sure about something.
current sound card-not installed at this time
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102012
current mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
current wireless card
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127329&Tpk=d%20link%20dwa%20525
So I am thinking of buying a new wireless card, something that is faster then the one I got as well as a new sound card but my video card currently blocks my pci express x1 card. Can a pci express x1 card be used in a pci-express x8/x4.
The only reason for a new wireless adapter is when downloading I can maximize my speeds. When I download on my wired connection I get double the speeds. I would just keep in connected to my wired connection but that means I have run a cable on the floor or up the wall. Something in a apartment I do not wish to do .
As well I need the PCI slot free once I can get a second video card for x-fire, so the pci-express 2.0 slots will be the only ones free for what I need.
AMD 970 3.5 Ghz
current mobo
