Sometimes when I start up my computer, my computer shuts down and then restarts and my bios configurations will "reset to default." I have to change my bios settings each time this happens. (Happens about 1-2x/week).
A few months ago, there was a power outage while my computer was running and when the power came back, I turned my computer back on and my computer started to "stutter" or pause on and off, but this went away after 30 minutes or so. It happened a few times after that but seems to be working fine now.
Are all these problems related to my power supply? (I am using a 4 pin connector to my motherboard's 8 pin slot)
Thank you
My Computer Setup:
1. Mobo- Intel DZ68BC Z68 Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121533
2. PSU- Antec earthwatts 380 watts power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
3. RAM- CORSAIR Vengeance 8GB Ram 1600 - 1.5V DDR3 CAS 9 low profile
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
4. CPU- i5-2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
5. CPU Fan- Cooler- Hypermaster 212 Plus-
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
My motherboard requires an 8 pin connector and i've been using a 4 pin (since my power supply only has a 4 pin- "12V(P4)"). My computer also should be using well under 380 watts using a power calculator.
Thank you
My Computer Setup:
4. CPU- i5-2500K
