4 Pin out axial cooling fans
Last response: in Components
- SolvedPC cooling fans 3 or 4 pin? Forum
- 4 pin cpu fan connector gave out. Can I connect the 4 pin fan wires directly to a power cable? Forum
- Side fan 4pin Molex Plug - Wire severed out of socket Forum
- APEVIA Power 3 PIN TO 4 PIN Fan Converter (Question) please help not sure if this will work out as i intend it to Forum
- Solved3 pin case fans to 4 pin header... can i change the fan speeds? Forum
- Solved4 to 3 pin y cable (for fans) Forum
- HELP! smoke came out of my 4-pin fan header Forum
- Solved3pin to motherboard 4 pin chassis fans Forum
- Solvedwill 3 pin fans run full speed on 4 pin mobo Forum
- SolvedCan you use molex fans with a 3/4 pin plug? Forum
- Solvedk281 cabinet preinstalled case fans 3 pin or 4 pin Forum
- SolvedCan i manually control the speed of my two 3-pin case fans if they are plugged in 4-pin slot? New to pc's - Pls help! :) Forum
- SolvedHow to slow down 4 pin fans Forum
- Solved4 pin Y adapter with 3 pin fans Forum
- SolvedHow to connect two 4-pin case fans to one case fan port on the mobo? Forum
- SolvedIs it ok to connect two old smps 80mm fans in series by a 4-pin molex connector in 12v connection? Forum
- SolvedFan uses 3-pin, MoBo takes 4-pin fans? Forum
- Solvedconnecting 3 and 4 pin fans directly to PSU Forum
- SolvedCase fans are running at full speed even though 4-pin Forum
- SolvedHow to put 6 case fans with only 3 PSU 4 pin Forum
- More resources
Read discussions in other Components categories
