Sabertooth Z77 Won't Recognize Ethernet Cable and Fans Won't Shut Down
January 3, 2013 10:26:45 PM
Hi,
My build has gone well except for one issue with LAN connection: it doesn't work at all.
I installed the drivers - it's just telling me there's no cord connected. Is there something easy I'm missing? I'm worried that I damaged it during my build. I discovered a sticker covering the LAN port AFTER I mounted the motherboard so I tried to fish the sticker out with needle-nose pliers. I still had to disassemble the entire thing to get the sticker off, but perhaps I moved a sensitive pin digging around. I tried multiple cords with no luck 9and they work with the PC I'm using to write this right now)
I hope there's an easier fix, but if I did waste the LAN connector I can just get a LAN card and plug it into the MB correct? That would bypass whatever mess I made. Any good brands?
Man, everything went so smooth... Argh!!!
One other smaller issue - my fans won't shut off after shut down. They keep spinning. Any thoughts on that problem as well?
Love this website - many helpful people all through this process. Any help now would at least help me sleep better tonight. :)
