Solved
Best cooling solution for cm 690 II advanced?
Build:
Mobo: Asrock Z68 extreme 7 gen 3
Gpu: two XFX DD Hd7970 BE in xfire
Cpu: i7 2660k
ram: hyperx genesis 4*4gb
cpu cooler: hpyer 212 evo
psu: corsair pro 1200 watts
case: cm 690 II advanced
Optical drive: Samsung SH-B123L
now, i need to know if all my componants can fit easily it the case and the best cooling solution (2 hd 7970 can get pretty hot). plz inlcude pics ^^ thanks in advanced
5 answers Last reply Best Answer
More about best cooling solution advanced
  1. Best answer
    it will all fit, the 690 II is a good size case and fits cards up to 30cm. the 7970 is 27.5cm long
    define cooling solution? your best bet would be water cooling but that is expensive and a DIY project (or more money to pay someone else to do it)
    your next option would be after market coolers for the vga but that is also expensive and you can put that money back into better cards
    if you are asking about fan placement then two in (front) and two out (back & top) will do the trick. you get diminishing returns after that.
    http://www.bit-tech.net/hardware/2012/02/10/the-big-cooling-investigation/10
  2. Although the Hyper 212 Evo is a nice cooler, I would go with ..
    Thermaltake Frio OCK @ http://thermaltakeusa.com/Product.aspx?C=1417&ID=2044
    or
    Thermalright Archon @ http://www.thermalright.com/products/?act=data&id=172
    or
    i'm actually quite the cm fan ^^
    alright, i was actually talking about fan placement and thanks for the answer
  5. Best answer selected by rolandftw.
Power Supplies Cooling CPUs Components
