I've decided to build myself a new PC but I'm having a really hard time deciding which graphics card to get. It seems the HD 6970 is a pretty formidable card, especially in a CrossFire setup. I've been doing some research though and the HD 6970 is apparently a pretty hot running card, especially in a CrossFire setup since there usually isn't enough space between the cards for decent airflow to get through. So I have a few questions about the HD 6970:
Will I be needing a case with really good airflow? Must I therefore avoid especially silent cases?
Will I need to buy a bunch of extra fans, and if so, were on the case will they be needed (Currently thinking of using a Fractal Design Define XL USB 3.0)? Is there even a point to run these cards in CrossFire without water cooling?
Are there manufacturers that sell extra thin 6970's or socket 1155 motherboards with handsomely spaced PCI-e slots for a decent price?
Also, what wattage is recommended for a 6970 SLI setup?
