So I am getting ready to build my 2nd computer, but I am nervous and just want to run all these parts by some more experienced people. This computer will be mostly for gaming but I am also going to buy home and student so I can take care of some work. I am hoping to keep the price under 1200 but I am planning to buy a few parts per pay check so if I go over that its no problem. I also plan to use some parts from my first build to save a few bucks.
I already have Case - Antec 900 Hard Drive - Western Digital VelociRaptor and a random 500GB
And I am planning on buying
Processor - Intel Core i7-2600K Sandy Bridge 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Mother board 1st choice- ASUS P8P67 DELUXE or Pro (not sure the difference)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701
Mother board 2nd choice - ASUS P8Z68-V PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
RAM - G.SKILL 6GB (3 x 2GB) DDR3 1600
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Power supply - Rosewill BRONZE Series RBR1000-M 1000W ( My last PS is Rosewill and it works great and is cheap!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188
Video Card- EVGA SuperClocked GeForce GTX 560 1G ( two of em)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130661
OS - Windows 7 premium 64bit ( Not sure if I will get the OEM or the standard /w support, I think I am willing to pay extra for some support)
I just want to make sure all this will work together and make sure I am getting optimal performance within my price range.
