Computer doesn't detect ethernet cable
Last response: in Networking
- Computer doesn't detect ethernet cable - Tech Support
- Computer Doesn't detect when ethernet cable connected - Tech Support
- computer doesn't detect my ethernet cable - Tech Support
- Ethernet port doesn't blink and the computer isn't detecting any cable or ip adress - Tech Support
- My newly built PC doesn't detect my Ethernet cable - Tech Support
- SolvedEthernet cable won't detect when plugged into computer. solution
- Computer does not detect ethernet cable in port. Need help please!! solution
- SolvedComputer won't detect Ethernet cable during the day? solution
- Computer dosent detect Ethernet cable solution
- Computer takes several hours to detect ethernet cable solution
- I have connected my ethernet cable to my computer and it says i got connection but the internet doesnt work. solution
- Just built a new computer and it won't detect my ethernet cable solution
- computer doesn't recognize my Ethernet cable solution
- Computer not detecting internet/Ethernet cable solution
- SolvedDesktop won't detect Ethernet/LAN cable solution
- Computer stops detecting ethernet cable Forum
- Solvedi connected my pc to the internet with a Ethernet cable now the wireless doesn't work solution
- Desktop (Windows 7) wont detect ethernet cable solution
- SolvedCod World at War co op doesnt work even in LAN with Ethernet Cable..Help! solution
- SolvedI connected ethernet cable to ps3 but it does not detect Forum
- More resources
Read discussions in other Networking categories
, one of the times when I had this problem I fixed it by reinstalling Windows (running Windows 7 64-bit) and that worked, but I would rather not do that again, don't want to loose all my music and games. My friend has had the same problem so he just reinstalled windows, there has to be another way to fix this thought right? I have already tried uninstalling the drivers and reinstalling them but that didn't fix the problem. Anyone have any suggestions?
