Hello,
Been reading on this forum a lot. So so helpful. Best On the net. I really hope someone can help.
Im really stumped. My computers details ....dell 435mt, 6gb ram,i7 920 Bloomfield,termaltake 650w grand psu (new upgraded from original),original mobo (bios 1.1.4),xfx 5770 graphics card (new upgraded from ati 4350),Blu ray drive and a DVD drive. Also from Ireland so 230v.
Right here's my problem....
Installed the psu (tight fit) connected the cables correctly and in the order termaltake instructed. Installed the graphics card. Closed up the case connected all other cables USB, power screen etc. Powered on fine. Windows loaded as normal. (was excited, not going to lie) I ran HWmoniter to check out my temp. Graphic cards GPU was 32c (old one 50-60c), CPU down a few degrees since the termaltakes psu fan was sucking heat from it I'm guessing. Overall pretty happy. I then went to the toilet. (5mins tops) Sat down, opened google Chrome to get the latest drivers for the card and as google opened the pc turned off, sorta! The screen when blank psu seemed to get quieter but the power button stayed on (power bottom colour - white) I waited 5mins. Didn't know what to do. Finally I held the power button to shut the system down fully. I disconnected the plug, reconnected and then hit the power button. Everything came to life for only a split second. The power button which turns orange first then white (normally that is) stayed a steady orange(amber). I freaked tho I fried the mobo or something.
Had to go to work so did.
Got home, tried to reset the CMOS in case it was a overheating thang. Nope didn't work. Power button stayed a solid amber and the fans just ran for a second each time. The PSU's fan also came to life but came to a halt after 30sec.
Removed the 5770 and replaced it with the old 3450. Tried again, Nope. Same thing.
Was getting worried.
Replace my Pc back to stock...bingo Pc turned on!!
Not the result I was looking for.
Thinking that card was faulty I tried it in a friends of and it worked perfectly.
My stock PSU and 5770 also boot but after 7-10mins the screen goes black/blank and the pc seems to stay on. (kind of like what happened the first time I installed both units)
Could my new termaltake PSU of shorted during the first use? (I have yet to test it in another machine) everytime I try it on my dell I get the solid amber light and live for a second.
Maybe the psu is to powerful for the board?
Would getting a new mobo fix this?
I noticed that my stock dells 24pin mobo has2 pins missing and the termaltake only one could this of caused the problem?
Also to power my CPU from psu I used the 2 4pin (they were stuck together) instead of an 8pin cable could this of shorted or damaged my psu?
I gonna stop asking and just post this. I'm known to ramble abit as you can see. Just trying to provide adaquate info.
Thanks in advance everyone,
Colm
Colm
