Problem with three display setup with ATi Radeon 6770 graphic card
Hello.
I got a new Dell XPS 8300, with ATi Radeon 6770 graphic card.
In addition, I have two 24 inch 1900x1200 monitors (1, 2) and one Full-HD TV (3).
This ATi Radeon 6770 graphic card have
- Two DVI
- One HDMI
- One DisplayPort
I plugged two monitors into two DVI port of graphic card,
and one TV into one HDMI port.
After that, I tried to set-up the display like this: (1) and (2) are expanded display, and (3) is a duplication of (2) --> in other words, 1 + 2/3 setup.
However, it didn't work at all.
When I tried this setting through the display setup panel of Windows 7, it reported the error message. and When I tried this setting through CCC, the duplication option disappeared after expanding the display.
Please give me an answer if there is an answer to set up 1 + 2/3 display.
I think the DisplayPort could be an answer, but I can't sure about that.
Anyway, I need an answer of either way, software(additional setting, etc.) or hardware(buy a cable, etc.).
Thank you very much.
2 answers Last reply
More about problem display setup radeon 6770 graphic card
  1. For 3 display to work on AMD card. One screen must be plugged to the display port. If you don't have a monitor that connect via display port, you need an active adaptor.
    http://support.amd.com/us/eyefinity/Pages/eyefinity-dongles.aspx
    That list is not absalute. You don't have to buy the ones suggested on the list. It is just there to help you as a guideline.
    Same situation here: Running Ati Radeon HD 6770 x 2 in crossfire, 2 dvi monitors one in each dvi port and and tv plugged in to usb to displayport adapter into display port on card. Everytime I try to enable any 3rd monitor it says, I have to disable one.??
Radeon Graphics Cards ATI Graphics Displays
