First build help
is this setup compatible? would it be good for advanced video editing and rendering?
Case: Coolermaster HAF 922
Motherboard: ASUS 1155 P8Z68-V S/L
CPU: Intel Sandybridge i7-2600K
GPU: Sapphire radeon HD 6870 1gb
PSU: Corsair Professional Series 750W. Is this power supply modular?
RAM: Kingston HyperX Genesis DDR3 1600MHz CL9 8GB
hard drvie: Western Digital Caviar Black 1 TB 7200 RPM
DVD rw: Liteon 22x Internal DVDRW
Water cooling setup: XSPC Rasa 450 RS120 WaterCooling Kit
Is there anything im missing? feel free to add or take anything you thing i dont need. i will be oc. This is the top end of my budget so anyway i can save money without impacting the performace too much. thanks for the help
1 answer Last reply
More about first build help
  1. yes its "compatible".
    Good for advanced video editing and rendering. You have a really nice CPU and good RAM (may need more for large rendering), your graphics card could be upgraded tho. It is perfectly fine if it too much $ for you.
    If you want to save money, don't get that case. You can find a cheaper one.
New Build Systems
