The power regulation on the MSI 970a g46 is it bad or something ?
I get all kinds of spikes on the 12v on the board monitor , goes up to 20.9 volts and down to 1.9 volts every 5-15 minutes . Is that normal or does this board have some known problems ? I changed the power supply 3 times , all give the same results , Ultra x=3 600 watt , Antec HCG 620 and an OCZ 700 can't believe the psu is the culprit .
Is this board a pos , I have an asus backup , think I should send this back to MSI ?
