Custom build, built to last - need advice
Last response: in Systems
Apologies, I did not know the link would bring up a login page. Hopefully this works, thanks for your help/advice.
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support FPB Video ...
CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 ...
Microsoft Windows 7 Professional SP1 64-bit - OEM
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
Related ressources
Looks like a good build only thing i would recommend is a little bigger PSU for future add on of more video cards in SLI or Crossfire or simply a bigger one that's more demanding on power, maybe up it to like 750W-850w, and for ease of instalation make sure its modular less unused cords in the case.
Ask the community
