No Sound from 990XA-GD55 Onboard Audio
I am running Windows 7 Ultimate 64 bit. My BIOS and driver are up to date.
I am just trying to use the green analog speaker port. I have a front and back port on the system. I have tried both, neither seems to work. Windows doesn't recognize when I plug into it. When I check the sound devices in Control Panel, it shows that there are two Realtek digital devices set as default. One is "default device", the other is "default communications device". It won't let me set Speakers as a default device, that option is grayed out. I tried plugging my speakers into the digital port and that did not work either, even though those devices are set as defaults. I'm at a loss.
1 answer Last reply
More about sound 990xa gd55 onboard audio
  1. First remove all drivers, download new ones from Realtek or from motherboard manufacturer and install them. The option to set default may be grey'ed out if its the only audio device.
Sound Cards Default Speakers Devices Components
