Parts Upgrading Question
Hello everyone,
I will be upgrading my mobo, cpu, and ram later this week. I will be keeping my 2 hard drives, (1 OS drive, 1 storage drive) and everything else.
When I first power up my machine with the new hardware, do I need to reinstall windows 7 fresh on my 1st drive, or is there a way to just boot up with the windows 7 cd?
I am asking because I'm not sure if I can just keep everything the way that it is or if I need to back everything up now and get ready to do a clean install.
Thank you.
3 answers Last reply
More about parts upgrading question
  1. I would back up your data (profile, Favorites, etcs.) first, then boot up w/your Win7 DVD and install a fresh install of Win7. It's a much better way of instaslling Win& even though some will say you can/should do the upgrade. I've been in PC IT for over 25 years and have always found a fresh install to be the best. You will have a much more stable system than you would with an upgrade.
  2. Yes. Fresh install is the best option for such cases.
    Well I wouldn't be doing an upgrade. What I was asking if there is a way I can boot right to the existing OS that is already on the HD? Like can I use the win7 cd as a boot up disk?
Homebuilt Windows 7 Systems
