Approximate Purchase Date: In the next month
Budget Range: $2000 - $2500 (with a little wiggle, but keeping it lower is better obviously)
System Usage from Most to Least Important: Photo / Video Editing, Graphics work, Gaming, Regular surf the web stuff
Parts Not Required: Nothing outside the box itself.
Preferred Website(s) for Parts: NCIX.com or http://memoryexpress.com/
Country: Canada
Parts Preferences: Dig the new Antec P280 case. Nvidia card preference for Mercury Playback Engine in Adobe products.
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: If I buy the Dell U2711 then: 2560 x 1440
I'm debating Picking up a Dell U2711 based on the $700 price on cybermonday (today!? so I may update this later if I pull the trigger) - I'm only debating because the Samsung SyncMaster LS27A850DS sounds really good as well and is new! at $850...
I'd PREFER my system be as quiet as possible - this is especially the case when idle. (I sleep in the same room!)
SO My current cart at NCIX.com is as follows... ( I am linking each item to it's product page on ncix)
Case: Antec P280 ATX Tower Case Black 3X5.25 2X2.5 6X3.5IN 2X120MM Top 1X120MM Rear Front USB3.0 No PSU
Processor: Intel Core i7 3930K 6 Core 12MB 3.2GHZ Hyperthreading Unlocked LGA2011 Processor
Motherboard: ASUS P9X79 Pro ATX LGA2011 X79 DDR3 4PCI-E16 2PCI-E SATA3 USB3.0 SLI CrossFireX Audio Motherboard
RAM: G.SKILL F3-17000CL11Q-16GBZL Ripjawsz 16GB 4X4GB DDR3-2133 CL11-11-11-30 Sandy Bridge E Memory Kit (TWO of this kit for 32 GB total)
Power Supply: Antec High Current Pro 1200W 24PIN ATX12V Active PFC 80 Plus Gold SLI Modular Power Supply 80MM Fan
HDD: OCZ Vertex 3 Max Iops 120GB 2.5IN SATA3 6Gbps Sandforce SF-2281 Solid State Disk Flash Drive SSD
Western Digital 2TB Caviar Green SATA3 Intelli Power 64MB Cache 3.5IN Internal Hard Disk Drive HDD
Cooling: Corsair Cooling Hydro Series H100 Extreme Performance CPU Cooler System LGA775 1366 1156 AM2 AM3 ((Though Not Listed - It DOES Support socket 2011)
GPU:
EVGA GeForce GTX 570 HD Fermi 732MHZ 2560MB 3.8GHZ GDDR5 2xDVI HDMI DisplayPort PCI-E Video Card
I'm coming in so far at $2,739.40 which.. is doable - but I also haven't hunted any deals I just built it strait up on NCIX for the time being. I tend to like NCIX only because I've ordered from them before... and have always had great experiences.
That's where I am at so far... I'd love all the advice I can get to be honest. I know the 2600k processors are champions and if I was just gaming I'd be all over it. But because I intend to move into more photo/video/graphics/effects editing
I felt the extra cores and cache made the 2011 socket make sense. Plus it should still be a beast when I do game
Country: Canada
Overclocking: Maybe
GPU:
