Power consumption of a monitor and cpu
Hello,
power consumption of a monitor and cpu
4 answers Last reply
More about power consumption monitor
  1. depending on *what* monitor and cpu.
  2. yes it will really depend on what....
    but i would say average 24" screen uses less than 30Watts.
    and a average cpu uses max 95Watts.
  3. again, it really does depend on the monitor and cpu (base unit?). It could be anything from under 100W for a basic system to over 1kW for a really high end nulti-monitor gaming system.
    A few of the power supply manufacturers have psu calculators which will give a better idea of the base unit power than we can give.
  4. A typical 24" LCD monitor with traditional florescent backlight is probably about 50w.
    A typical 24" LCD monitor with LED florescent backlight is probably about 25w.
    Current CPUs can range generally range between 40w (low power & reduced speed) to around 180w (Phenom II X6 1100T) at 100% load.
    Don't forget that video card also use power from as low as around 15w for a non gaming card to 400w for a Radeon HD 6990 under 100% load
CPUs Power Consumption Monitors
