Hey everyone. First time builder/poster. Working on an i5 based system and am looking for some GPU/ HDD advice.
Approximate Purchase Date: sometime this month, hopefully… (comments below)
Budget Range: $1,000-$1,500
System Usage: Gaming/ web browsing, probably office suite later
Parts Not Required:
MOBO: ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
CPU Cooler: XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233081
DVD: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 – OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Case: NZXT Apollo ORANGE NP Orange SECC Steel Chassis ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146027
--Have to admit, bought this one for aesthetics/price point. Seems to have sufficient cooling and good reviews, but will I have to buy another case fan if I want to overclock?
Ram: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Preferred Website(s) for Parts: Newegg/ Tigerdirect, but otherwise open if there’s a better price
Country: USA
Parts Preferences: ??? (I was hoping you guys could help with this)
Overclocking: Yes
SLI or Crossfire: probably not, unless there’s a good reason to
Monitor Resolution: 1920x1080
Additional Comments: I would like some advice on a good GPU for around $350 or so (a little flexibility with the price, but of course want the biggest bang/buck ratio.) I have read that a single GPU is better at 1080 and this price range, is that true?
Also, it seems that I picked a bad time to need to buy a HDD... since the flooding in Thailand made prices increase dramatically. Is it the opinion of this forum that HDD prices will calm down anytime soon, or will they stay at these levels for the foreseeable future?
and of course, I would appreciate being pointed in the right direction about what's good for both of these components. ^_^
Projected component purchases:
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_mmc=ET2011_listing-_-343-_-N82E16819115072&nm_mc=ET2011_listing
hoping to catch a good deal on Tuesday (internet blew out in the morning, sold out by the time I got it back. =P )
PSU: CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Will this PSU be good for the system that I’m building?
Thanks for your input!
Parts Not Required:
Country: USA
Overclocking: Yes
