Monitor doesn't recognize computer need help.
Alright, so the computer worked 100% until I went in the BIOS and applied a VERY minimal over clock from 2.8ghz to 3.3ghz. I increased the voltage from stock to 1.35v on my AMD X6 1055t. After that I rebooted my my monitor never recognized my computer again so I RMA'd the GPU, CPU & MOBO. I've tried new ram and a new PSU as well. Still getting "No signal" I have also tried a different monitor as well. I've also tried resetting the BIOS with jumpers like it said in the manual and removing the battery to reset the CMOS. I even used different RAM in different slots as well. I have done almost everything and need help.
Specs:
AMD 1055t
ATi 6870
8GB G.skill DDR3 1600
Biostar TA99FXE
Cougar 650w 80+ certified
1TB 7200rpm seagate
2 answers Last reply
More about monitor doesn recognize computer help
  1. You will probably get better help here:
    http://www.tomshardware.com/forum/forum-33.html
    So do you get anything when you boot up your computer? Or is it just 100 percent non-responsive.
    It is 100% unresponsive.
Computers Monitors Components
