Hello,
So, this is my first ever computer build and I'm finding that neither of my 2 fans for air intake in the front of the case are working. They don't even light up to show there's power running through them. However, the cables run through to the front panel which works. I've been thinking that maybe I should try buying a fan-to-psu adapter, but I'm not sure how to go about this. I've looked online, but still finding myself scratching my head as to what it is I need exactly; all I know about the front fans are that they're 3-pin 120mm fans.
here are some of my specs if that helps:
case: corsair carbide 400r
mobo: intel dz68bc
cpu: intel i5-2500k sandy bridge
ram: corsair vengeance (8GB)
gpu: evga gtx 560ti (not hooked up yet, mobo wouldn't boot so i figured i needed to update the drivers first)
mobo: intel dz68bc
