Hello everyone!
I was initially going to buy a GTX 590 but I've heard problems about it and so I've decided that I would SLI two GTX 580's. Although I am having trouble choosing which 580 to get. My parts will be bought off of Newegg.ca.
Feel free to go through the complete list of GTX 580's here
I am sort of stuck between these cards:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130590
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130658
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130587
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130655
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814162073
I realize the core clock of some of them is higher and I am not 100% sure what this means. It seems that some of the cards are the exact same at a higher price.
Also note that I trust EVGA as a brand but the Galaxy brand 580 has 3 fans built on with a $50 rebate.
Please help me choose which would be the fastest and which would be the cheapest and which would be the perfect balance.
Thank you so much! I appreciate it!
My system specs if you need them are:
Intel 17 2600K
Corsair Silent Pro Gold 1000W Power supply
Asus Maximus IV Extreme-Z Mobo
16GB of 1333Mhz Gskill RAM
Intel 17 2600K
