I'm having an annoying issue with this motherboard. The compatibility list has CMT4GX3M2A2133C9 on it which is a 4gb kit of Corsair dominator GT but since that was withdrawn I bought the replacement 8gb kit
CMT*GX3M2B2133C9. It's technically the same memory just in an 8gb kit so there should be no issues.
However, when I enter the bios the memory originall was running at 1333mhz instead of 2133MHz and every time I tried to set it to normal specs the computer would not post and the motherboard displayed error 23.
I tried XMP profile and that also crashed.
The computer runs fine at any speed below 2133 and I am currently running the same memory at 1600mhz with cl7 timings. But i'd like it to run as it should and wonder if anyone out there knew a fix? I'm unable to test any other memory as this is my only set of ddr3 memory.
Is it me just being a bit silly or should I be worried about this at all? I'm certain the performance difference would be minimal but it's frustrating to see tbh. Especially when there is a pair of fans cooling these dimms of underclocked memory... -_-'
A little help please ^_^
