Corsair memory help
,I have a Motherboard GA-970A-DS3 Which i know Supports Dual channel Memory ok, but my problem is if i get 4 sticks of memory/16gb which is this one http://www.ebuyer.com/248759-corsa [...] 3m4a1600c9
I am asking if these are compatible and will run dual channel mode on my motherboard and if they do not could you show me some other ones thanks I need to know if i will run in dual channel mode or not and if it will does it matter which sticks i put together? I need to know this thanks but the main point i need to know is will the 4x4 memory cards work in my motherboards dual channel mode and i always though dual channel means 2 cards only?
2 answers Last reply
More about corsair memory help
  1. They'll work in dual channel mode no matter how you plug them in.
  2. Yes, they are comaptible with your mainboard and will work in dual channel mode.
    Your motherboard has 4 memory banks, two blue and two white. Each color is one channel, so you can have two or four modules working in dual-channel configuration.
Corsair Dual Channel Motherboards Memory
