On ATX power supplies, if the mb has a 20 pin and a 4 pin connector and your power supply has a 24 with 4 removeable and also a 4 pin stand alone connector, which do you use. the 4 pin plug seperated from the 24 pin or the stand alone 4 pin. the 4 pin from the 24 pin connector has red, yellow, orange and black whereby the stand alone 4 pin has two yellow and two black. If properly oriented, they will both go onto the cpu 4 pin receptacle?
