So, I had recently bought and installed a phenom x4 975 processor, probably about a month ago, and I'm wondering if I have some heat issues. With the Stock cooler, Temp's reach about 59 degrees Celsius playing Assassin's Creed: Revelations on maxed settings at 1440 x 900 res. According to Coretemp, the temp's don't linger around that range but only drop to around 55-56 degrees celcius. Knowing that 62 degrees is that max safe temp for the CPU, I'm wondering if this is normal. The only program that are running in the background is Steam.
Also, My Voltages are hitting 1.45V, which is about .05v higher than what is advertised on their site but I've seen that other's on other forums also have their voltages going this high. But of course, that doesn't make it safe.
So what's wrong here? Is the product defective? How could I check for issues?
